92 vx cable reel/clock spring
The horn on my 92 civic vx doesn't work, but the srs light is not on. Could the reel still be bad? I checked for power to the horn wires on my wheel with a test light and got nothing. What's should I do?
Re: 92 vx cable reel/clock spring
Check the horn relay on the side of the under dash fuse box. White/green wire is power. If you have power then try grounding out the blue/green wire of the horn relay.
Check all fuses.
Check all fuses.
