Oil on Spark Plugs
Oil on Spark Plugs
Doing a tune up today. Noticed a bit of oil on #4 spark plug.
Is this bad?
I know that oil can leak due to valve cover gasket leaks. Is this a really bad one or can it go a ways?
If it really needs it, then it will have to wait till next month.
Let me know what you think
Is this bad?
Re: Oil on Spark Plugs
looks like you're running a bit rich how old are those plugs. the threads look like "glass" maybe that's just your camera tho. i'd wipe it off put it back and see if it does it again.
they're about 15k miles old, i just put in some new ones. I'll see what it looks like tomorrow.
The threads aren't glass they just have some **** all over them.
If it's rich I should adjust timing I guess?
well do what jbpnoman said then worry about it running rich(if it actually is). I know they're not really glass just said it looked like it.
Could be leaky valve cover. Hopefully its not a leaky head gasket, could do it too. More plugs would probably have oil if it were your head gasket. No temporary fix. New gaskets are a must.
It's my Galaxy S3 if you can believe that.
I think it just looks so nice because it's one of the few pictures on this website that isn't blurred all to hell.
Pardon me if this is a stupid noob question as I've never done a gasket job before, do I have to remove the spark plugs when removing the valve cover?
No you don't need to pull them. Stuff some paper towels/rags in the holes to keep debris out
Lmao- X 2 on lousy pictures. I always take 2 shots in case 1 is crap-
Thanks guys, it's pissing rain and the garage is full of books and clothes and the vanity that's never going to get refinished.
The engine is indeed a D, it's a D16Y8
What's the idle supposed to be on the D16Y8 auto?
It seems to usually idle at about 750/800 when warm but sometimes it will drop down to 500 or less if I'm stopped at a light.
This is after the tuneup as well.
When's the last time the throttle body bore And Both sides of the throttle plate was thoroughly cleaned? Cleaning iacv and t/b usually fixes idle issues. Check air cleaner, too. Low idle is Usually a restriction in the intake tract
