Rear T-bracket help
Rear T-bracket help
I need some help. I have a B16 swap into my 94 coupe and is this the right t-bracket or do I need a Integra one? It would line up perfectly if I pushed my engine back enough, but before i do that, I want to make sure its the right t-bracket.
I can't upload any pictures at all, no matter what way I try, so I'm just gonna post the links
http://postimg.org/image/h5p1u7a8n/
http://postimg.org/image/9hlu2fn45/
http://postimg.org/image/f1c81mnoz/
Re: Rear T-bracket help
If its the t-bracket for that motor ten it's right. If its a t-bracket from a d-series motor then it's wrong. A t-bracket from 94-01 integra and 99-00 civic si b-series is what is needed.
i wouldnt even be concerned about the bracket at this point..why is there a completely broken hole on the trans...hard to see from the pic but i see a fcked up hole.
Thank you all ^ I bought the car and I guess the guy that did the swap only put one bolt in it. And then one day my shift linkage was laying on the ground because the rubber piece that flares out on the metal bar, well that bar came off. Then I jacked it up to find this
blackccoupe
03-12-2014 08:52 PM
wade
10-25-2008 06:02 AM
