over heating
over heating
ever since i got on it yesterday the car has been actin weird so i get on it again today and it started to over heat so i let it cool did it again same **** put more anti freeze in it and oil still does it what could have happend please help
Re: over heating
kinda sounds like you popped the head gasket is there coolant in your oil does the oil look like chocolate milk does it smoke (constantly)
Re: over heating
yeah i checked oil its good and no smoking going to check compression tomorrrow tho is there any thing else it could possibly be
Re: over heating
Thermostat could be stuck closed.
Warm engine up and see if all coolant lines get warm. Put heater on hot, and check those lines also. If they do, then you at least know that coolant is flowing.
When you add coolant, be sure to add a 50/50 mixture. Too rich on antifreeze will cause your car to overheat. I would also check your mixture with the a floating tool to make sure it's good.
When is the last time you flushed your cooling system?
Re: over heating
na its been like that ever since it was changed and if it was blown it would be way lower cuz before i changed it the **** was real low
Re: over heating
How old is your water pump? Check for an external leak. However, a seal could have released internally and the pump efficiency went out the window.
-Change thermostat
-Flush system with Prestone radiator flush.
-Refill with fresh 50/50 mix
-Check or replace water pump
Cooling systems are fairly easy. If it's not an internal engine issue, than it should be relatively easy to diagnose.
-XLR8
-Change thermostat
-XLR8
JM Performance
07-07-2004 08:17 PM
