92 civic dx with ls/vtec swap
Old 01-12-2009, 05:58 PM
95civiccpdx's Avatar
Default 92 civic dx with ls/vtec swap
ok so i have a 92 civic dx with a ls vtec b18b block and a gsr head at about 1500 rpms it seems like it studders it has pr3 cam gears it seems like timing is off but it looks dead on the pcv valve is capped off i dont kno if this will make a diff and also i have a dx so my map sensor is on the firewall should i be using the harness from the car or the engine harness??
Old 01-12-2009, 06:27 PM
z6hatchboy's Avatar
Default Re: 92 civic dx with ls/vtec swap
any cel's? i think i had to use the car harness with the map sensor deal on my 92 because im thinking it was a tight fit. Timing could be off too though, or ignition coil
Old 01-12-2009, 06:35 PM
96electronH's Avatar
my friend has a lsVtec in his crx and it cut cut out during vtec and he advanced the timing a little on the dizzy and it seems to have solved it. it may not be the fix for you but im just shooting advice
Old 01-12-2009, 06:40 PM
thanks no no cels im gonna try to time the dizzy tommorow well see what that does someone told me stock cam gears cant be used on these engines because the timing will never be right does anyone know if thats true
Old 01-12-2009, 06:41 PM
Endo-land's Avatar
Definitely use the firewall map harness. That is the wiring to the ecu.
Old 01-12-2009, 06:43 PM
ok im thinkin maybe the map sensor has alot to do with it
Old 01-12-2009, 06:46 PM
racemycivic's Avatar
you have to use the dx map sensor (which is on the firewall) technically your timing will never be PERFECT persay by using stock cam gears, but you should not be hesitating like that, adjustable cam gears will allow u to make it perfect, but i would say look into the pcv valve being capped and check the vaccums. good luck
tigueremalo
07-25-2006 05:10 PM
raider099
06-21-2004 03:14 PM
mattssi
14
03-24-2004 07:00 AM
simplypinoyy
01-13-2004 09:03 AM
South Bay Surfer
11-23-2002 01:08 AM
Quick Reply: 92 civic dx with ls/vtec swap
