asr rear swaybar
asr rear swaybar
if i were to buy the asr 24 mm rear sway bar what else would i need for install here is were i am buying it from https://www.jhpusa.com/store/pc/view...idproduct=2057
Re: asr rear swaybar
you will need to up grade your LCA's (lower control arms) to aftermarket ones that have previsions for the endlinks
you might need the endlink im not 100% if what your looking at comes with it
and i would STRONGLY recomend you buy a subframe brace because you will be at high risk of ripping a hug whole trhough your subframe and then ull be f*****
ive seen horrible pics of swaybars with out braces and the effects
buddy of mine has the complete ASR kit with sway bar and brace and its amazing on his sol
