wheel stuck to knuckle.
so im replacing my axles and had to move my car like 20 feet, so i put the wheel on with no rotor and now its stuck to the knuckle part..
anybody know how to get the wheel off? im stuck. thanks
Re: wheel stuck to knuckle.
if none of the above solutions work then again with the single lug nut tighten it with a ratchet while its up in the air (not as tight as torqueing it) then lower the car and carefully and slowly drive back and forth a few feet and then jack it up remove the lug nut and the wheel will be loose.
