What qualifies as a full tune up?
this weekend i'm getting the car to a garage to get a tune up done, but because i have 2 CEL's and the fact the car misfires, etc. i wanna get a full tune up
the engine is a D16Y7
Oil Change
Timing Belt
Plugs
Dizzy Cap and Rotor?
what else? im a bit lost, and i dont wanna waste my money on stuff i don't need
Oil Change
Timing Belt
Plugs
Re: What qualifies as a full tune up?
biggest thing is finding out why it has cels and fix that and find out why its misfiring.
fuel filter,pcv valve,
how many miles does it have? and do you know how well the car was taken care of?
i know the CEL's are, TPS senson and o2 sensor
150k, and well the P.O. bashed up the body pretty good, trunk doesn't line up all the way, door have big dents in them, mechanically it wasn't maintained that well..just random oil changes from time to time
If you are going to do the timing belt then also change the water pump (since the timing belt has to be removed to change it).
timing belt
water pump
tensioner
plugs + wires
dizzy cap + rotor
oil change
tranny fluid change
02 sensors
pcv valve
fuel filter
Quote this post and add to it to make a master list.
water pump
tensioner
plugs + wires
dizzy cap + rotor
oil change
tranny fluid change
02 sensors
pcv valve
fuel filter
You should laway change both at the same time since they are connected. It will save you labour costs in the long run plus it gives you precious piece of mind.
Oil Change
Timing Belt
Plugs
Oil Change
Timing Belt
Plugs
plugs (NGK)
wires (NGK)
cap and rotor
air filter
throttle body cleaning
PCV (if needed)
oil change including filter and plug washer
checking tire pressure
most everything beyond that would be checking the condition of things like fluids, tire tread, belts, hoses...
and for the record, a good T-belt package includes more than the belt and a water pump. you should get the outer belts, VC gasket, crank and cam seals thermostat and gasket (should be replaced with new waterpump) and a valve adjustment (because they're already in there.)
I definately suggest a fuel system cleaning. Go grab a bottle of Sea Foam and let your car breathe. Don't be alarmed by how much smoke comes out of your car, the more smoke, the better. If you never have used Sea Foam before, look up a tutorial on the web, there is a lot of good write-ups and its a fairly easy/cheap and effective thing to do. I just did it today actually to my neighbors Dodge Ram 1500.
pinks11
16
02-25-2009 08:24 PM
Toofresh559
11-02-2007 05:09 AM
sony224422
08-11-2007 11:26 AM
