p28 ecu on d15b setup...
Im going to run a p28 ecu on my d15b setup. Would i have to get a 4 wire o2 sensor instead of using the 1 wire o2 sensor thats already on my d15b?
Re: p28 ecu on d15b setup... (eg6ajk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk »</TD></TR><TR><TD CLASS="quote">since its a p28 it needs a 4wire 02 . if you chip it to P08 specs then you can run
1 wire.</TD></TR></TABLE>
alright thanks. i read your post about the d15b...lots of great info your the man! keep up the great work!
Re: p28 ecu on d15b setup... (ABK)
So thats the only problem im going to have (o2 sensor) by using my p28 on my d15b setup? Any other problems that i should be aware of?
Re: p28 ecu on d15b setup... (trooper0641)
I did this swap about 3 weeks ago, its super simple. Only thing extra you need to do is run the 2 wires for vtec if your car isnt already wired for it.
Re: p28 ecu on d15b setup... (Slammd Sol)
ya you have the only problem covered with the p28 is just to convert to 4 wire O2, other then that ur home free....(unless the ecu is an automatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammd Sol »</TD></TR><TR><TD CLASS="quote">I did this swap about 3 weeks ago, its super simple. Only thing extra you need to do is run the 2 wires for vtec if your car isnt already wired for it.</TD></TR></TABLE>
i got a 92 hatch so its suppose to already have "vtec-prewired" LOL
Werent you the Del Sol guy who just swapped a d15b? How does it run? From a scale to 1-10?
GERBERBOII
03-17-2010 02:27 PM
dblock91
02-03-2005 05:58 PM
hYbRiD EeEkAy
08-16-2003 10:51 PM
