Tein SS Coilover after install question
I did not have time to take pictures, as the morning I lowered my car I was already about late for my plane back here to Iraq. I'm not sure if you will be able to help out, but here is what I saw.
The front right coilover, after lowered seemed to almost be sticking up from inside the engine bay. What would cause this?
If you have any questions let me know, I did not do the actual install myself, but the guy doing it knew what he was doing..perhaps he just forgot something?
Thanks.
Thanks.
Re: Tein SS Coilover after install question (Solracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solracer »</TD></TR><TR><TD CLASS="quote">Is it the top of the shock sticking through the bushing? If so he left off the washer that goes below the tower mount.</TD></TR></TABLE>
I 2nd that.....
I 2nd that.....
Re: Tein SS Coilover after install question (SloCivicHMM)
That sounds about right.
I honestly had about 5 minutes to drop my car and push it back into place before I left. Hard night of drinking the night before was not a good idea.
Thank you
Thank you
Re: Tein SS Coilover after install question (phreakmang)
I have a similar question. What washers should be used? I just installed my ss last night with the same washers i was using on my koni yellows. After a test drive I hit a huge hole (figures right, first drive with em) and the drivers side rod went through the bushing similar to phreakmangs problem. I havent took the shock out to check it but I would think the center hole on the washer might be too big and the rod went through. Hopefully there is no damage. What washers have you guys used?
Re: Tein SS Coilover after install question (drnitrus)
Found the problem! I used the washers from the Koni yellows. Big mistake. These washers have a bigger opening than an oem washer due to the konis having a thicker rod (lol). The freakin washer went about a quarter of the way down the rod. Luckily I was able to slide the washer off without any damage to the shock but know I have a small dent on the hood. Sucks!!
Yeah like everyone else said you probably left off either the top or the bottom washer. Get it fixed though or you'll end up w/ the shock going through the hood I did the same thing... twice.... on my car. It took me lowering it and it not looking right for me to realize I left the bottom ones off, and then driving and having one of the rear bushing pop off to notice I needed top ones... rushing these things is a bad idea
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloCivicHMM »</TD></TR><TR><TD CLASS="quote">
I 2nd that.....</TD></TR></TABLE>
I 3rd it. I had to deal with that same problem on both my rear shocks 2 weeks ago. whoops!
