y7 throttle body on y8 manifold
I've heard that I can use my y7 throttle body on a y8 intake manifold, is this true? What do I need to modify to do this? TIA.
Re: y7 throttle body on y8 manifold (Cowtit)
u can use it. if u have a y8 auto manifold u don't have to mess with anything. if its a 5spd y8 manny u either have to leave the iac bolted up to the manny or plug up the holes for it.
Re: (sohc_boy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_boy »</TD></TR><TR><TD CLASS="quote">not really, if u are looking for a cheap upgrade try and find a used integra t/b.</TD></TR></TABLE>
They're exactly the same except for the position of the bracket that connects the throttle cable to the TB.
You'll need a throttle cable bracket/spring (attached to the butterfly on the TB) from the y8 if you plan to reuse the y7 TB.
Re: (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
You'll need a throttle cable bracket/spring (attached to the butterfly on the TB) from the y8 if you plan to reuse the y7 TB.</TD></TR></TABLE>
and the iac on the y7.
Re: (sohc_boy)
and the iac on the y7.</TD></TR></TABLE>
Yes. I forgot all about that. It's already attached to the TB though, so he won't have to mess with it.
eltexmexalex
12-29-2016 06:00 AM
slow_SIvic
03-24-2007 08:29 AM
Cashieboi
10-20-2006 08:38 PM
_HANS
16
05-17-2006 01:21 PM
