Spark plug wires are a bitch..
Changing spark plugs on a gsr motor in bubble..
The firing order is correct.. the car doesn want to start?? It just turns over and doesnt turn on..
Plugs gapped proper, wires on corret,
Could a fuse have blown?
Any other suggestions on this..
I know its a stuipd topic but im lost i Messed with it for ilke 1 hour and got nowwhere..Thanx for all help..
Re: Spark plug wires are a bitch.. (EjCiViC)
u didnt happen to fry your coil by chance did u? that happened to me when i replaced my wires, long story short, wire fell off while driving and grounded the coil against the rad support. dead car.
Re: Spark plug wires are a bitch.. (jameskersten1)
How did u check to see if the coil went bad?
Not sure if i did, i mean it turns over but doesnt start,,, just turns and turns?
Re: Spark plug wires are a bitch.. (95turbohatch)
i just replaced mine honestly cuz i had an extra sitting around so i didnt waste too much time testing the old one. just elimated fuel and spark as reasons for no start. replaced the first thing that could cause no spark. it will crank over but wont fire. if you got a person to help you, pull a wire out and turn it over with the plug close to something metal and see an spark? go from there.
yea it was so cold out side tongiht i was so pissed i didnt want to bother..
but yea so ill have to do whole dizzy cause i dont have extra coil just laying around..
Im getting fuel so its def a spark issue
What if im getting spark? blown fuses? i mean i checed already nothing seems to be blownand all grounds look fine to me
Ok, spark, fuel are all good, grounds are good,Thought it might dizzy so i chaged it, rotor also, tried differnt ecu still not working ,
Nothign is workin...
SO agrivated, dont know what else to do..
Anyhelp would be great
going over to help tonight:
Things i plan on doing aside from looking at it and evaluting from there:
listenign for fuel pump upon swithcing key to on,
gas level
grounds
spark check via holding wires above plugs while trying to start and listening for spark
possibly new ingniter coil
gas level
grounds
Re: (dohcdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol »</TD></TR><TR><TD CLASS="quote">Did ya have the clutch pedal down????
Seriously, what was the final problem and solution?</TD></TR></TABLE>
if the clutch wasnt down...the engine wouldnt even crank...maybe you blew the computer chip in the engine bay area...
Re: (sohc_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_civic »</TD></TR><TR><TD CLASS="quote">
if the clutch wasnt down...the engine wouldnt even crank...maybe you blew the computer chip in the engine bay area...</TD></TR></TABLE>
It was a joke I know it wouldnt krank, im just being a retard
Re: (sohc_civic)
And what computer chip are you referring too? If you don't know what your talking about, keep it to yourself?
Re: (mattssi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi »</TD></TR><TR><TD CLASS="quote">
And what computer chip are you referring too? If you don't know what your talking about, keep it to yourself? </TD></TR></TABLE>
i was talking bout the ecu chip inside the engine bay area where the fuses are...in my eg there's a fuse box next to the battery. check in there....
I had the ****** clutch pedal down all the way thanx u very much...
It ended up being that im a moron and had the firing order reversed , even know i checked it over like 500 times.. im just a moron, wasnt myself.. and i am pissed at myself.. dont need anyone elses bullshit
Re: (lsi crx)
Sorry Hondatech..
I was feelin liek **** 104 fever, shoulnt have been workin on car, wasnt my self.. so i took a day off and then went back to it.. boom first try got it.. it was a dumb mistake.. so ****** hate all u want
Re: (95turbohatch)
It happens to the best of us. Believe me, none of us are perfect, reguardless of what they want you to believe.
for getting it figured out.
Sometimes just stepping back or having a second person check it out is the best thing to do.
whoobeedoobee
08-06-2003 05:03 PM
