Sway bar or no sway bar
as of now, i have an h22 eg. it iwll jsut be used for street driving and drag racing. i got complete gsr suspension on it, as well as the sway bars. the front one is fine, but the rear one is an issue. i cannot get my exhuast to fit with it there. its 2.5 inches. will this really benifit me that much for my application, or should i jsut leave it on and pay a muffler shop to rebend me the axle back area of the exhaust
thanks
thanks
i want to go pretty low, or at least as low as i can go with the h22 axles. i have agx, and ground controls, so i can shnge the drop, but i would rather have it go between so i do not have to worry about the ground clearance
Re: (c1civic)
what exhaust are you runing?
if your runing a traditional style muffler then i was in the same boat i just told them it had to fit and the guy at the exhaust shop made it fit.
if its a canister style i would route it under the sub fram. you can still go farly low with this setup just don't give the muffler a huge slant up and down thats were you run into trouble.
but all in all, i just have a B series motor and there is no way i would run no rear sway bar now you threw some more weight up front, and there is no way in hell i would do it
im runnin the canister style.....thanks for the help, suspension is not my strong part...it seems i will jsut keep it, a fork out a little money and have them make it fit...any idea what this should cost me??
square_1
01-27-2009 06:35 PM
