How is it the rear LCA being is able to be changed to the ITR one without doing the 5-lug Convo
Re: How is it the rear LCA being is able to be changed to the ITR one without doing the 5-lug Convo
i dont quite get the question, but are you saying something like your car came with R lca without the 5 lug?
if so then the previous owner put that R lca to run a type R shock/spring combo.
If you're asking how it works, it's b/c its about the same size as the EG / non R DC chasis LCA's and has the same connecting points... I believe it has the lower shock connection a little lower down than the eg does, but I'm not quite sure on that. Basically people change it out, like stated above, so they can use type-r suspension components (i.e. shock/spring combo)
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by =GAMEOVA= »</TD></TR><TR><TD CLASS="quote">i dont quite get the question, but are you saying something like your car came with R lca without the 5 lug?
if so then the previous owner put that R lca to run a type R shock/spring combo.</TD></TR></TABLE>
Yep, that is what I was trying to say but I didnt know how to ask the question.
Filliam H. Muffman
12
07-04-2006 03:05 AM
SwedBoy2999
11-21-2004 05:56 PM
rocket3004
04-24-2003 09:53 AM
