3rd gear grind after new clutch
apparantly GSR trannies are infamous for grinding 3rd, but mine never did it before i put the new clutch in. it didn't even do it after for a while. then my master cylinder went out. That was replaced, and now it grinds. Not only at high rpms either, it grinds all of the time, unless i let the rpms go almost all of the way down and pause before i stick it in third. I don't get it. I thought it might be the sloppy shifter (I was runing a bolt in my linkage) so i put in a new bitch-pin and some ES shifter bushings, and GM Synchromesh (not the friction modified kind). But the thing still grinds. I don't even drive the car that hard....well sometimes, but not that often. Could it be a bent shift fork or something like that? please help
Re: 3rd gear grind after new clutch (thehatchninja)
Did you just "add some" GM synchromesh or did you completely drain out the old stuff and fill it full of GM?
Re: (thehatchninja)
On an EG I don't think you can adjust it. The only thing you can do is blead it....I could be wrong. Cable trannys are a whole different story. You can adjust those quite a bit. My first guess is still that is has something to do with the fluids....
Re: (thehatchninja)
anyone?
p.s.....i'm sure you can adjust the pedal/MC... i'm just not sure how...i can probably figure it out...i'll try tomorrow.
taimysho0
09-24-2007 05:15 PM
