K20 Swap into a EK
K20 Swap into a EK
I've already done some searches came up with very few none helpful threads. I'm planning on doing a K20 swap into my EK as the topic states.
What kind of engine wire harness should I find or build for the 99-00 EK?
I heard the the K20 transmission can be implanted to the EK, is that true?
Can I use the stock K20 shift Linkage?
How much would a performance custom header custom made for an EK?
Will I be using a reprogramed K20 ECU or a modified "P" something ECU?
Is there any type of frame modification to fit the K20 in?
Will I be able to use the K20 axles or will I have to purchase some aftermarket ones?
Will I need to change or modify the throttle cable or does it just hook straight up?
Does AC still work after the swap is complete?
Thanks in advance.
Thanks in advance.
Re: K20 Swap into a EK (mp7235)
Contact K20eg through AIM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mp7235 »</TD></TR><TR><TD CLASS="quote">I've already done some searches came up with very few none helpful threads. I'm planning on doing a K20 swap into my EK as the topic states.
What kind of engine wire harness should I find or build for the 99-00 EK?his harness is plug n' play or he can make one for you
I heard the the K20 transmission can be implanted to the EK, is that true?if your talking about to a stock EK motor no, since the tranny is on the wrong side, but yes it is included in the mount kit
Can I use the stock K20 shift Linkage?It is not a linkage it is cable shift and yes you can
How much would a performance custom header custom made for an EK?His headers are going to be a production piece they are almost ready to be released price is pending great construction though very very nice piece
Will I be using a reprogramed K20 ECU or a modified "P" something ECU?you have to use the K20 ECU since nothing else will work BUT you can get hondatas new program called Kpro it looks like it will work well i have no experiance yet with it but i will soon
Is there any type of frame modification to fit the K20 in?Not that i am aware of i don't think there is
Will I be able to use the K20 axles or will I have to purchase some aftermarket ones?they have to be made but K20eg takes GSR or RSX axles as cores they arn't that expensive
Will I need to change or modify the throttle cable or does it just hook straight up?not sure
Does AC still work after the swap is complete?i believe it can be maintained
Thanks in advance.
Thanks in advance.
Re: K20 Swap into a EK (99blackcivicSi)
go to http://www.k20a.org there is a ton of very interesting as well as usefull information there. and as previously said contact k20eg he knows a **** load on the swap and related knowledge.
good luck should be a monster when its done
misha
misha
Re: K20 Swap into a EK (EG TYPE-R)
or how about a pic?!?! my girlfriends away til thursday and i could use some bathroom material
lmao, sike but for real any pics? i've only seen them in EG's... and i drooled all over my "rock out with my **** out" shirt
Re: (95DXPhiladeph)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DXPhiladeph »</TD></TR><TR><TD CLASS="quote">or how about a pic?!?! my girlfriends away til thursday and i could use some bathroom material
lmao, sike but for real any pics? i've only seen them in EG's... and i drooled all over my "rock out with my **** out" shirt </TD></TR></TABLE>
What up .
I got a one coming out shortly. This Ek is owned by Mr. Vtecvoodoo
What up .
Re: (K20EG)
you just rocked my world... i cant wait to see it.... i've got an EG with an EK front end and I'm wondering how the engine looks with the EK headlights... i think it looks more in place than the EG...
HOWEVER you could slap that thing in a plymouth duster, that engine is SIIIIIIICK
Re: (Morhpeous)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Morhpeous »</TD></TR><TR><TD CLASS="quote">http://www.hybrid-racing.com all k20 mounts, custom headers, wire harness, axles, everythign here</TD></TR></TABLE>
you might as well refer him to a criminal...cause thats what hybrid is.....all he did is copy k20eg.....
Unceasing Measure
Re: (Morhpeous)
Hybrid-Racing is a bunch of ******* crooks. Buy straight from K20EG unless you want inferior knockoffs of a product from inferior people .
K20EG's kits are beautiful, quality, lifetime guaranteed products and, in the off chance that they failed, he won't give you the runaround about replacement. Honestly, K20EG is the first person I've talked to with both the capability and the entrepenureal spirit who cares more about spreading the K20's popularity and reliability instead of making money. Props to K20EG and buy his products!!! .
Re: (Morhpeous)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Morhpeous »</TD></TR><TR><TD CLASS="quote">wow thats really good to kno i had no idea about that... i guess i wont spread the hybrid racing word anymore its all bout k20eg </TD></TR></TABLE>
Don't buy from k2o he lives with a guy! I mean, go to Eric for your k2o needs. He's the man!
