AC problem, really need answers and help!
Old 08-29-2004, 12:18 AM
Civicpmp4's Avatar
Default AC problem, really need answers and help!
Im having an AC problem, The problem is when any time I drive, the AC works and get cold, but when I stop at the light, it gets to the normal temperature outside... and the fan of AC condenser dont run...Why is that?
Well I try they fuse, I try pluging the fan straigh to the batters and it runs... is there something wrong with my Regalutor or electirc problem?
So what can I do? bring it to the shop?
Old 08-29-2004, 12:20 AM
Civicpmp4's Avatar
Default Re: AC problem, really need answers and help! (Civicpmp4)
Well the AC seems cold today, and seems to be pretty cold when the motor first started... but Im still concern about the condensor fan, it wont run why is that!
Old 08-29-2004, 12:26 AM
BatuKing's Avatar
is the compressor clutch engaged when the fan is off?
Old 08-29-2004, 04:40 AM
Civicpmp4's Avatar
Default Re: AC problem, really need answers and help! (BatuKing)
What you mean Compressor Engage? its just shut off, never run....
Old 08-29-2004, 09:12 AM
Octoman's Avatar
Is the condensor fan off while the compressor is spinning? I think it is, since he states that it cools ok while he is driving but not at all whenthe car is stopped. You should check to see if you have a bad condensor fan relay. Also check to see if the fan works by connecting it to the battery with test clips. It is probably a bad fan or relay.
Old 08-29-2004, 11:46 AM
Civicpmp4's Avatar
Default Re: AC problem, really need answers and help! (Octoman)
I think its the Relay, because I wired the condensor fan right to the battery and it work, but if I dont do that then it dont... Wierd as mother... I dont really know anything about relay so it makes me even harder to figure out.
Old 08-29-2004, 02:06 PM
BatuKing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicpmp4 &raquo;</TD></TR><TR><TD CLASS="quote">What you mean Compressor Engage? its just shut off, never run.... </TD></TR></TABLE>
NO you said it works when your driving and when your at a stop it turns off.. the fan is off but my Question to you is to check the compressor to see if it is engaged.. Why well if the condenser is not getting any airflow then the temps will go up.
kruiz15
05-14-2016 01:42 AM
Maurice24
08-15-2010 06:43 PM
duyfash0
10-08-2008 06:46 PM
civicman022002
05-23-2006 06:55 PM
Quick Reply: AC problem, really need answers and help!
