My car is throwing code 7 TPS - throttle position sensor
Old 08-30-2004, 06:33 AM
Jaydeep's Avatar
Default My car is throwing code 7 TPS - throttle position sensor
My 2000 civic EX car is throwing code 7 TPS - throttle position sensor. Does anyone know how to fix that. What could be wrong?
Old 08-30-2004, 07:07 AM
Cnote's Avatar
Default Re: My car is throwing code 7 TPS - throttle position sensor (Jaydeep)
plug wire could have become damaged
maybe VAFC/SAFC was installed inproperly
ZEX wire was installed wrong/incorrectly
maybe your tps sensor just failed and you need to replace it.
Old 08-30-2004, 07:30 AM
Spade's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaydeep &raquo;</TD></TR><TR><TD CLASS="quote">My 2000 civic EX car is throwing code 7 TPS - throttle position sensor. Does anyone know how to fix that. What could be wrong?
Well, you probably don't have a warranty anymore. The cheapest thing would first be to check the wiring and connector.....it's on your Throttle body (BTW) and then clean the connector. Then get a votlmeter and test the output to what the Haynes/Helms manuals say.
Old 08-30-2004, 08:14 AM
Jlo96Hatch's Avatar
just replace it you can pretty much get a tps from any other civic or integra etc.
Old 08-30-2004, 09:47 AM
Jaydeep's Avatar
Default Re: My car is throwing code 7 TPS - throttle position sensor (Cnote)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cnote &raquo;</TD></TR><TR><TD CLASS="quote">plug wire could have become damaged
Check engine light came on when I took off valve cover to check if my timing is ok. So I don't know what I did wrong.
But I checked plug wire they are good
Can some one tell me where is tps sensor is located at. My friend got same car so I could replace it and check.
Old 08-30-2004, 11:14 AM
Slopoke's Avatar
Default Re: My car is throwing code 7 TPS - throttle position sensor (Spade)
Can some one tell me where is tps sensor is located at. My friend got same car so I could replace it and check.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade &raquo;</TD></TR><TR><TD CLASS="quote"> The cheapest thing would first be to check the wiring and connector..... it's on your Throttle body </TD></TR></TABLE>
Spade already answered that question.
Its on the back side of your throttle body.
Old 08-30-2004, 11:54 AM
Jaydeep's Avatar
Default Re: My car is throwing code 7 TPS - throttle position sensor (Slopoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke &raquo;</TD></TR><TR><TD CLASS="quote">
Its on the back side of your throttle body. </TD></TR></TABLE>
What is throttle body. I know it is stupid question but I really don't know.
Old 08-30-2004, 12:29 PM
IVI
IVI's Avatar
thats my throttle body with the intake arm removed.
if you look at the 3 wires connected to the throttle body (yellow, green, red) that is the TPS.
check the tps, by taking a multimeter and make a small incision in the middle wire with a razor blade to expose wire. and check the voltage of the tps by connectiong black to ground, and red to the exposed wire.
with the key on but the car off, you should get about .32 - .45 fully closed throttle. then slowly open the throttle with your hand and the voltage should increase slowly until WOT being at about 4.5v.
if you open the throttle and the voltage doesnt increase your tps is bad.
Thagoldenb
01-03-2011 11:00 AM
hotxcivic92
01-10-2008 12:48 PM
k624ash
09-09-2007 07:32 PM
T_bones
05-21-2006 05:35 AM
137
04-01-2005 12:23 AM
Quick Reply: My car is throwing code 7 TPS - throttle position sensor
