Does ECU Jump trick work on '00 civic?
I was just looking at the thread for jumping the two pins on the ecu on a '92-95 civic will that also work on a '00 civic lx?
I wanna grab my error codes easily witout a scanner!
Thanks.
Thanks.
Re: Does ECU Jump trick work on '00 civic? (jaycapz)
ya, you should be able to. just look on the pass. side footwell and see if there are two plugs, jump the 2 wire one
Re: Does ECU Jump trick work on '00 civic? (LSVtecEK1)
Its the top two correct, the ones right next to each other that must be jumped?
Then two clicks to just on, and the check engine will blink, nothing else needed?
Thanks.
Thanks.
Nichelson_Performance
07-06-2010 04:14 AM
Redz_EX
05-14-2007 08:57 AM
