Need help ASAP!!!
Need help ASAP!!!
Well I tried putting my 95 B18C swap into my 00cx yesterday, and ran into a whole load of different problems. My biggest problem is the distributor. I did a search but didn't find any that could help me.
I tried to repin my distributor, to find out that OBD2b D16y7 clip is no different than an OBD1 clip. So, I had to rewire my harness to fit the distributor. To my surprise the colors are not the same between the 00si harness and the OBD1 distributor harness.
Does anyone have the color codes for the distributor and the harness?
Also, for the extra plug on the distributor that has two wires. The SI harness only has the Black/Yellow wire, and does not have the Blue. Does this affect it in any way?
For those of you trying this swap, you will also need a GSR fuel line (not fuel rail) and throttle cable.
Re: Need help ASAP!!! (coachkellum)
I did a search, but they all pretty much say the same thing.
Ex:
Just remove the two wires from the bottom and repin them.... That may be true for OBD2 distributors to OBD1, but I have OBD1 distributor to OBD2.
Another Ex:
They are all the same color... No they are not. The OBD2 harness has a lot of solid color variations while the OBD1 distributor has more multi-color variations.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coachkellum »</TD></TR><TR><TD CLASS="quote">sounds like your in a bit of a jam. try searchin these topics have been around for years </TD></TR></TABLE>
Ex:
Another Ex:
Re: Need help ASAP!!! (98JDM_Type_R)
why not just get the gsr harness and be done with? i have an extra gsr harness laying around if you want to buy it.
Re: Need help ASAP!!! (hondaeg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg8 »</TD></TR><TR><TD CLASS="quote">why not just get the gsr harness and be done with? i have an extra gsr harness laying around if you want to buy it. </TD></TR></TABLE>
GSR harness won't fit into an EK.
Re: Need help ASAP!!! (hatchi)
Injectors are covered... Just use the stock one off your SOHC and the alternator. You can even open up the alternator and switch out the regulators so that it will plug in.
There is another thing that you will need: GSR Throttle Cable
By the way, I already fixed the problem w/ the distributor. Now, I'm on the even more problems. I should've gotten a B16a2 outta a SI to save from the headaches.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi »</TD></TR><TR><TD CLASS="quote">that's not the only problem you will run into. you will need alternator, fuel injectors. </TD></TR></TABLE>
MoogieBoogie
08-05-2005 06:30 PM
vxnine
07-25-2005 05:49 PM
