Symptoms of Bad Idle Air Control Valve
Old 08-30-2004, 12:04 PM
jaycapz's Avatar
Default Symptoms of Bad Idle Air Control Valve
Hey, someone suggested that my IACV might be bad. I have a '00 Honda Civic, I need to know how I can test it, and where I can find it and best / easiest way to change it. And what does something like this cost?
Thank You - in advance!
P.S. I checked the ECU, theres no error codes being thrown.
jaycapz is offline
Old 08-30-2004, 12:19 PM
IVI
IVI's Avatar
Default Re: Symptoms of Bad Idle Air Control Valve (jaycapz)
IVI is offline
Old 08-30-2004, 12:39 PM
B A N N E D
vtecb20coupe's Avatar
Default Re: Symptoms of Bad Idle Air Control Valve (IVI)
what symptoms does the car have that would make you think the sensor is bad? the car will idle real bad and may not stay started.
vtecb20coupe is offline
Old 08-30-2004, 12:53 PM
Kesall's Avatar
Default Re: Symptoms of Bad Idle Air Control Valve (vtecb20coupe)
How would you distinguish between a bad EACV and a bad fast idle valve? My car does idle badly (only until it warms up) and sometimes will not stay started. I was told it was the fast idle valve, but I'd hate to replace that only to find it was the EACV causing the problem.
Kesall is offline
Old 08-30-2004, 01:16 PM
jaycapz's Avatar
Default Re: Symptoms of Bad Idle Air Control Valve (Kesall)
Car Starts up with no problem, once started idle is fine. Put it in drive, drive for a couple of minutes, once a lil warmed up and come to a complete stop, idle comes to almost stalling .... putting on A/C SOMETIMES helps to kick up the idle just enough to keep it running. Turn off AC, car starts to shake, lose idle quickly.
Sound about right? I dunno what else to look for to be honest.
jaycapz is offline
Old 08-30-2004, 01:17 PM
jaycapz's Avatar
also, thanks IVI for the posting, but where more clearly can i find this thing?
jaycapz is offline
Old 08-30-2004, 03:36 PM
IVI
IVI's Avatar
no problem
that is the actual part.
its bolted right behind the "G" in PGM-FI
2 - 12mm bolts hold it on, with 2 lines at the bottom for coolant.
IVI is offline
Old 08-30-2004, 03:46 PM
haccord2.2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaycapz &raquo;</TD></TR><TR><TD CLASS="quote">Car Starts up with no problem, once started idle is fine. Put it in drive, drive for a couple of minutes, once a lil warmed up and come to a complete stop, idle comes to almost stalling .... putting on A/C SOMETIMES helps to kick up the idle just enough to keep it running. Turn off AC, car starts to shake, lose idle quickly.
Sound about right? I dunno what else to look for to be honest.</TD></TR></TABLE>
You might want to check the timing I had the same symptoms as you with my civic when I first got it and it drove me nuts I finally checked the timing with a timing gun and come to find out my timing was all messed up, someone before me had changed the timing belt and got the camshaft pulley off two teeth and then messed around with the ignition timing to get the car to run. So I fixed all the timing and now the car runs better than it has ever run since I have owned it. Just thought you might like to know this if the IACV is good. Well good luck.
haccord2.2 is offline
Old 09-12-2004, 11:07 PM
jaycapz's Avatar
Default Re: Symptoms of Bad Idle Air Control Valve (haccord2.2)
Timing is good, put up the idle a drop, injector cleaning and new distributor cap its all working good now.
BUTTTTTTT ... I m getting a low buzzing noise from the IACV area, right between the 2nd and 3rd fuel injectors ... but right below the air intake box. So, my question is, could the IACV make a buzzing noise if it is clogged or somethign wrong with it? Is there a quick and painless way to check it out? Or a easy way to clean it out? It is a lil pricey to just replace correct?
All info is appreciated! Thank you for the pics and posts! Very helpful.
Oh yea, i have the '00 civic, so that pic is a lil off from mine... what is that? An older accord or prelude?
ALSO IVI you said that it seemed like air wanted to come out of the intake ... strangely enough i get the same thing. When i take out the filter, rev it, air pressure shoots out that small hole above the throttle plate and hits the plate as it opens to make a wooshing sound. Did you find out what that was? That has started since I got this buzzing noise from the IACV area.
Modified by jaycapz at 3:21 AM 9/13/2004
jaycapz is offline
Old 03-14-2014, 11:34 AM
ramzan1966's Avatar
Its true I had the same problem and replacing the plastic component of the valve and cleaning the metal part solved the issue
ramzan1966 is offline
Old 01-15-2016, 04:20 PM
Midnight.Vibez's Avatar
I have a 91prelude. Its a manual. It starts good never wants to stall but when I'm at a complete stop whether I'm in gear or not the car starts to idle drop from 2k down to 1500. My buddie told me he had the exact same problem and said it was his IACV. I just wanted to know if it was the same thing.
Midnight.Vibez is offline
Old 01-15-2016, 05:13 PM
I never narc'd on nobody!
NotARaCist's Avatar
12 year old thread
Not even in the correct subforum
You already know where the Prelude section is. Quit bumping ancient, dead threads here, and go back to posting there.
NotARaCist is offline
self_made
04-10-2021 02:25 AM
stuckinmud
08-14-2009 08:32 AM
95civic16
05-23-2008 12:22 PM
rdeezy25
05-17-2005 01:55 PM
Quick Reply: Symptoms of Bad Idle Air Control Valve
