KNOCK SENSOR? OR HARNESS OR?? HELP!
i swapped intake manifolds on my gsr...(EG hatch)..... now below the intake manifold is this green sensor which is the knock sensor im guessing.....its green top...... so the harness got disconnected from the green sensor thing....... so do i need a knock sensor or just the harness that goes into the knock sensor? i can probably find the harness part in a junkyard?
btw the check engine light comes on......and the car idles...... so im assuming all that is cuz of the sensor not being connected...
Re: KNOCK SENSOR? OR HARNESS OR?? HELP! (CrazyHB)
Yes, that's your knock sensor.
Now is the harness broken or the sensor? Can you reconnect it?
If you do, you must remember to pull the battery connection for at least 30 seconds to clear the ECU code(s)
Re: KNOCK SENSOR? OR HARNESS OR?? HELP! (Spade)
well the harness is disconnected from the sensor...... the sensor will still go in place..... so i guess the harness is broken? im not sure how to reconnect it exactly.....
It should be a straight forward plug that goes on the end of the sensor with 1 wire coming off of it.
