Electrical Problem Help!
Im having some electrical problems in my civic. When I press the brake pedal all my parking lights come on. When I let go they turn off. I put a test light to the fuse connector that controls the parking/instrument/license plate lights and only one side comes on when I turn my lights on. A friend that took a look at my car said something is backfeeding but he couldnt figure it out. Is there anything that I could check to fix this. Hope someone can help. Thanks.
Re: Electrical Problem Help! (93civicsedan)
you know what....my instrument/license plate lights don't work, which connector is it that you're checking?
bump for you too
bump for you too
A few other ppl where having the same proplem in there sols, Id search to see if they ever came up with a solution, But like i told them too its propably a short in the wireing harness somewhere, Id check it from the tail lights going towards the front of the car, When i looked at the wiring diagram i dident see anything simple that both circuits shared like a light switch or anything so, Good luck man be sure to let us know!
There is no switch to check its a short in the wiring harness somewhere you have to follow that thing from the lights all the way back to the car and look for the short.
shdow8948
05-19-2011 08:53 AM
KRAP DIVAD
11-28-2009 06:44 AM
