d16z6 shifter fork in d16y8?
Re: d16z6 shifter fork in d16y8? (food4less562)
you should find a y8 fork cause i know they are made alot stronger than the z6. and it is possible to break the z6 fork, so if i were you, id find another y8. im sorry i know that doesnt answer your question.
For some reason I am going to say no..I cannot explain why, but do remember reading something about this not long ago. While they are the same tranny (basically), the forks are made of different materials
1 Post
Re: d16z6 shifter fork in d16y8? (civic-4-ges)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges »</TD></TR><TR><TD CLASS="quote"> While they are the same tranny (basically), the forks are made of different materials</TD></TR></TABLE>The Y8 is made of steel whereas the Z6 is made of aluminum, but I believe they're interchangeable
Re: d16z6 shifter fork in d16y8? (hatchling37)
no they are not interchangeable,I remember reading a while back that although the tranny gear ratios are the same, some of the inerds and such are not and it will not work. Don't quote me on that but I did read it. I would stay on the safe side and get a y8 one plus if you can get a z6 shift fork, why can't you find a y8 one?
Re: d16z6 shifter fork in d16y8? (Hella_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">i asked this a while ago , and it was said that they were NOT interchangeble
That is correct.
That is correct.
Re: d16z6 shifter fork in d16y8? (Ricey McRicerton)
I allways thought they were but they were made out of different material, Is that why your saying there not interchangable?
Re: d16z6 shifter fork in d16y8? (nocternaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocternaldragon »</TD></TR><TR><TD CLASS="quote">I allways thought they were but they were made out of different material, Is that why your saying there not interchangable?</TD></TR></TABLE>
That is correct. BauleyCivic tried it a while back in one of the 50 times that he tore his tranny down and it won't work.
Ok, cause i allways thought that they were the same size and all but one was made stronger then the other, which is why ppl wanted the z6 one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocternaldragon »</TD></TR><TR><TD CLASS="quote">Ok, cause i allways thought that they were the same size and all but one was made stronger then the other, which is why ppl wanted the z6 one.</TD></TR></TABLE>
z6= aluminum so it breaks
y8= stamped steel so it bends before it snaps
People want the y8 one because when it gets torn up its not a catasrophic failure like with the z6.
Ok, thanks guys for that question. I posted another question, but someone locked it. It was about the "clutch release fork". Clutch release fork and shifter forks are two totally different things. So is the clutch release fork interchangable between the d16z6 and d16y8?
OpTiX619
07-27-2004 12:47 AM
