HELP ME PLEASE!!! ALL MY GAUGES QUIT WORKING! ON MY EG
I was driving to work on tuesday when I look down and notice my tach,speedo, gas and temp guage are not working whatsoever...I notice my clock on the dash doesnt work either...I pushed the button in like as if the car were off and you wanted to check it. and it lit up. It seems to keep time but wont come on with the car. ALSO my Turn signals do not work!!! as well as some other stupid ****. like the dummy lights for my seatblet,e-brake and hatch open.
All this seems super weird. I first thought it was a bad ground. I checked the two grounding points that I know of and they both seemed fine. ( the one on the kick pannel driverside and the one behind the cluster) I also checked the battery and all the motor groungs and they also seemed fine. I was thinking maybe there is a problem with the switched power cause they just didnt seem like they were getting power. But the lights all work as well as the Radio when the key is turned on. I called the Honda dealer and they said I would have to bring it in. --Screw that too much time and money I dont have right now--
Also my horn and reverse lights do not work but I dont think they have worked as long as I have owned the car...
ANY HELP WOULD BE SO SO GREAT!!! PLEASE!!!
could be many things. check your fuses box and main relay. your cluster could of gone bunk on you. something wrong with your dizzy. possibly something with the vss.
Re: (jerbear!)
CHECKED ALL THE FUESES... where would the main relay be? and even if the cluster did **** out on me shouldnt somthing still work? by the way the lights on it still work as well as the cruise control light. And when I use the 4-ways the turns will flash and the lights on the cluster will light up too..Its frickin weird!
Re: HELP ME PLEASE!!! ALL MY GAUGES QUIT WORKING! ON MY EG (Hondogg)
Got all the gauges and the turn signals working! ( Had to change the entire fuse pannel) weird, it was somthing internal.
But I cant get the horn to work...
Still dont know why yet. has power to the relay just doesent get to the horn. Just guess I keep cheking the wire along the way
LoGaN-VanG
23
06-20-2009 08:32 PM
Harrold
03-25-2008 06:20 PM
SlowPokeEg
15
01-21-2008 09:31 AM
