tranny blown need help
what up guys, yesterday wanted to drop it into second at 45, started going almost readline and something just snapped, so im just stuck in second so im sure i need a new tranny and clutch, should i get this check out for more problems? im afraid i messed up the flywheel or something thanks
Re: tranny blown need help (H.A.R.T b16a1crx)
most likely you blow up the clutch but tranny is a possibility u won't know until u take it all apart and check eveyr thing out. drain your tranny fluid see if you can see any metal shaving come out if there is the tranny probly blow a barring or a fork.
Good luck
Good luck
OBDII Integra
09-11-2009 08:56 PM
