how to clean my nasty stripped trunk?
i stripped out my trunk today and removed my system and ect for weight reduction and i was wondering, how can i remove all the grime and dirt and **** out of it?? i tried to vaccum it but it dont get the built up dirt grime mold ect ewwwwww what should i try to make it look vewwy clean :D
Re: (ek hatchhh)
If you haven't already, use a heat gun to pull up the tar since you are going for weight reduction. Then, hit it with the degreaser and some elbow grease.
Re: (maxpsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxpsi »</TD></TR><TR><TD CLASS="quote">If you haven't already, use a heat gun to pull up the tar since you are going for weight reduction. Then, hit it with the degreaser and some elbow grease. </TD></TR></TABLE>
a heat gun sucks really bad for doing that, use dry ice i have done this enough to know if my count is correct i have done 6 cars with the dry ice method
Re: (99blackcivicSi)
i was thinking about this today, since im goina have spring break up soon ill have free time. just one minor setback. um, wat kinda gloves should i use? haha, yea i figured garden gloves might freeze, and so will rubber gloves if im holding the ice too long. oh right, wats an estimated time this takes, i heard 20hours from someones write up but he took so long to remove the seems also. a good 2-3hours sounds reasonable
simplycomplex
Honda Fit
08-22-2014 11:26 PM
cilvia
26
02-07-2006 06:48 PM
