B16 tranny leaking fluid...possible to fix?
Well being my eg is lowered it scrapes every once in a while on bad spots, and the tranny I guess is leaking pin drops of fluid from one of the seal rings...So i'm wondering if its possible to put a weld over it or some sealant to stop the very small leaking or any other ideas would help...
1 Post
Re: B16 tranny leaking fluid...possible to fix? (skaterguy)
is it leaking around the axle seals?if so,they're very cheap and very easy to replace.
is it leaking where the two tranny halves meet?if so,you could split the case,clean the mating surfaces and reseal them.if the cases have actually been damaged from t e contact,you may have to replace one or both.
BTW-raise your damn car up!
Chris
Chris
Re: B16 tranny leaking fluid...possible to fix? (TeamNextGenChris)
it's leaking from one of the very thin rings that are not removable...not sure what they are called but it looks like a very thin circle, I will take a picture in the morning
AgentJam
10-16-2003 04:03 PM
