difference betweeen Z6 bottom and Y8?
Re: difference betweeen Z6 bottom and Y8? (B16aDasher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16aDasher »</TD></TR><TR><TD CLASS="quote">y8 oil pan is different. </TD></TR></TABLE>
But not that difference. Ive run a z6 oil pan on a y7 before - just gotta modify it a little to fit where the y7/y8 runs the dip stick.
The major difference between the motors is the y7/y8 have different pistons. The ring lands are closer to the tops of the pistons, which is good for emissions but bad for turbo and FI.
Same crank, same rods, same bearings etc etc
liam
liam
Re: difference betweeen Z6 bottom and Y8? (liam821)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 »</TD></TR><TR><TD CLASS="quote">But not that difference. Ive run a z6 oil pan on a y7 before - just gotta modify it a little to fit where the y7/y8 runs the dip stick.
liam</TD></TR></TABLE>
WOW, so does that mean i could run a b8 oilpan on my y8 block?
WOW, so does that mean i could run a b8 oilpan on my y8 block? </TD></TR></TABLE>
b8 what?
b8 what?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 »</TD></TR><TR><TD CLASS="quote">b8 what?</TD></TR></TABLE>
d15b8 94 cx oil pan on a d16y8 shortblock?
d15b8 94 cx oil pan on a d16y8 shortblock?</TD></TR></TABLE>
If you drilled a hole for the y7/y8 oil stick - yep it will work. You also gotta drill some holes for the screws that hold the pan to the block - it doesnt line up perfect. But its easy to make it work.
liam
liam
Circuit Star-29
62
11-09-2004 06:58 PM
