Shock went through hood...still good to use?
Well I've always heard about it happening but now I've become a statistic ...I was changing my oil today and saw the shock piston out past the usual....so far it made a hole on the bottom side of my hood...at least it didn't go through...question is...if i fix this...is the shock still good to use...or should I just get another one? Thanks!
UPDATE: I took the shock out and this is what I found
Modified by teameracer3 at 11:02 AM 3/19/2005
Re: Shock went through hood...still good to use? (teameracer3)
it looks as though something wasnt installed correctly. it should be good to use still.
Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">if the rod isn't scratched (which could ruin the seal on the shock), it should be fine to re-use</TD></TR></TABLE>
It looks like there could be some scoring on the rod (it may be grease or something), and if so, junk it.
same thing happened to me. forgot a washer somewhere. my teins were fine to use after that tho. but mine didn't go through my hood so hopefully yours are fine.
Re: Shock went through hood...still good to use? (screwballz)
yo dufus there's a washer that stops this it goes on after the bumpstop and before the 2 bushings and the sleeve not tryn 2 start nething but that what my uncle called me when i did the same thing
