lighting problem
lighting problem
hey i noitice that my center light in the car doesnt work. I thought the bulb was blown so i bought a new one. But wen i installed it in it still doesnt work. If it a problem with the fuse which fuse should i replace.
1 Post
if you are talking about the dome light, check the terminals for power first. if there is no power, get your meter and check all the fuses in the box under the column and in the dash. the fuse is usually the same one as the clock and radio IIRC.
