vibration on right side of car when car is being pushed hard
I'm pretty sure it's a bad shaft that came with my swap, but just getting feed back before I fork out the cash for a new one. I have a 98 ek with b16a(2) swap w LSD tranny and when I am really on the gas the right side of the car vibrates and sometimes makes a noise when doing sharp turns. It is fine when just doing normal driving.I have jacked up the car and everything is tight and no play in the wheel. all the motor mounts look good. I have narrowed it down to the shaft but I just want to make sure I'm not over looking anything.
Re: vibration on right side of car when car is being pushed hard (projectek)
check ball joints, bolts from when you did the swap, everything. doesn't hurt to double, triple check. as for the axle, could be. usually they have a slight shake, and click when you turn after they have gone bad. hell, i've even heard them click when braking, you never know.
Re: vibration on right side of car when car is being pushed hard (philosofy1)
inner joint on the axle prolly gone bad...but like he^^^said double and triple check bolts
any possibility this could be caused by the final drive falling out of place when the shafts were replaced? even though the car shifts fine?
Pagley
10-15-2009 09:01 AM
projectek
07-26-2006 09:45 PM
gsl_05
06-07-2004 10:55 PM
