Integra Blinker relay On civic??
hey hows it going... i have side markers on my sol... and ive noticed that integra lower blinkers, switch from one light to another/back and forth blinking on their corner lights... ... so i'd like to have that same sort of relay go inbetween my corner light and my side markers... i saw some ek that had side markers... and it had the light going from the side marker, to the blinker, back and forth... not at the same time... it was switching from one to another back and forth... i havent been able to find anything on it... can someone pls help??
http://forums.clubsi.com/showf...age=0
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">here are two wiring options. USDM (Sidemarker only blinks when turn signal is on) or JDM (Sidemarkers stay on and blink alternately with the signal). Pull back the fender liner and remove the corner/parking light. There will be 3 wires going to the bulb. Tap into the corresponding wires for each blinking style.
USDM:
Tap into green(turn signal) and black(ground) wire.
JDM:
Tap into red(parking light) and green(turn signal) wire.</TD></TR></TABLE>
USDM:
JDM:
Re: (Muttly)
USDM:
JDM:
ok so ... for the wiring on my side markers.. i just tap into the parking light... and green turn signal wire... well as far s the wiring on the side marker itself.. which goes to which...? and its that simple to do it like that?? they'll stay on and blink alternately... i just have to tap into red parking light and green turn signal?? cus yeah right now they just only come on when the blinker is on...
JDM:
Re: (egcivicdelsol)
Took me a second to figure out whats different about your car
The wiring should be correct. The relays should be the same, its just how the lights themselves are wired/powered. BTW if you don't use solder/shrink tubing, cover the connectors with the liquid electrical tape or dielectric grease to prevent corrosion.
Re: (egcivicdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcivicdelsol »</TD></TR><TR><TD CLASS="quote">USDM:
JDM:
ok so ... for the wiring on my side markers.. i just tap into the parking light... and green turn signal wire... well as far s the wiring on the side marker itself.. which goes to which...? and its that simple to do it like that?? they'll stay on and blink alternately... i just have to tap into red parking light and green turn signal?? cus yeah right now they just only come on when the blinker is on...</TD></TR></TABLE>
yes. try it one way and if it works the way you want it to then stop but if it doesn't, switch them around. hopefully that helps
JDM:
Re: (egcivicdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcivicdelsol »</TD></TR><TR><TD CLASS="quote"> its for my sol...</TD></TR></TABLE>
i love the eg front on the sol! that **** looks so clean!
integraracing91
12-03-2006 03:43 PM
