Block with missing sensors please HELP
so i sold a complete longblock to this kid and he never used it. when i bought it back he decided to strip it off the sensors. Yay for me (not really)
so i did some searches and figured out that the sensor to the left of the oil filter is the oil pressure sensor.. but which one goes to the right of it. its a threaded hole about the same size as the one on the left. is that the engine coolant temp?
btw the motor is B18B1 to be used in an EG
thanks in advance for the help
Re: (pdiggitydogg)
i didnt think these had a knock sensor...
so the 2 sensors i need are knock and oil pressure.. that go on either side of the oil filter..
can i get a confirmation
Re: (pdiggitydogg)
i thuoght only the vtec blocks had em... im not 100%
as for the year its supposed to be 94-96ish.. but i dont have the head so i cant tell
Re: (pdiggitydogg)
your the man for putting up a picture...
see there that plug is to the right of the oil filter that for me is open...could i just order that plug and screw it and call it a day. plus the oil pressure switch/sensor witch is completey missing
the upper plug, with the 14mm hex drive slot?
you should have 2 of those
the lower one, is where the stock pvc breather canister goes - it is not threaded
joedr
11-09-2008 12:11 PM
