b18 on a 97 EK
b18 on a 97 EK
well i found out that my d16 has a couple of miles left in it and i was wondering if a b18 would be a good swap so please let me know wether its a good swap or a bad one thnx.
First off, what kind of b18? ls, gsr, type-r, etc.
Second, if you search you can find a lot of information on what you are looking for as well as information on how to swap it into your car.
Re: (Tuesdaynightfever)
by the way it sounds he/she? wouldnt know how to swap a motor but thats okay most people dont..
figure out what motor your looking for and then begin to do some reading if your planned to seriously mod your car
Re: (b18civic_22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18civic_22 »</TD></TR><TR><TD CLASS="quote">the b18 is an ok swap...do you wanna go fast or just haul a lil ***? i got a b18C-R and it scoots! </TD></TR></TABLE>
wtf is a b18C-R?
wtf is a b18C-R?
Re: (Top-Fuel)
best advice for anyone willing to swap, is to look at your budget. Even if you have enough money to purchase an engine, make sure you still have extra cash (eg. $1000-2000) cause you never know what you might run into and every situation is different depending on your engine.
As for B18's, if you search, more specifically a B18C1 is recommended for turbo's (BOOST) where as a B18C5 is recommended for N/A. I myself have bought a B18C5 and plan on going turbo. Just because I already have a B18C5 and like to be abit different.
Bottom line is, do what ever you basically want because I personally think no matter what question anyone has asked about, such as engines or modding in general, its been done by someone already.
Ek Forever y0!
Re: (Top-Fuel)
I would go with the b18c1, basic gsr motor. Then with the $1000+ you saved instead of buying a b18c5, buy a b16 head and put it on the gsr motor. This will be more similar to the type r motor as the heads have the same blueprints. If you want while you have the b16 head out change the valvetrain to better that of the b18c5 and then put it on. This is called a "poor man's type-r." That's my plan for my civic. I've driven an ek hatch with a gsr-poor mans type r, and it was super bad-***. Much faster than the regular Integra gsr.
Re: (BaD_NeWz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BaD_NeWz »</TD></TR><TR><TD CLASS="quote">i went to a muffler shop by where i live and they told me tht they would do the swap for $6,000 smog legal is that too much????</TD></TR></TABLE>
lol, depends if you like to get raped or not
Re: (BaD_NeWz)
W O W!
I had my swap done because I didn't know how to work on cars at the time and it was $1.1k, smog legal.
W O W!
Re: (BaD_NeWz)
lol. I guess that's not bad to do all the work and get it ref'd for you.....
Me on the other hand, i spent about 800 on my lsvtec setup...
Re: (Hcivic02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">I would go with the b18c1, basic gsr motor. Then with the $1000+ you saved instead of buying a b18c5, buy a b16 head and put it on the gsr motor. This will be more similar to the type r motor as the heads have the same blueprints. If you want while you have the b16 head out change the valvetrain to better that of the b18c5 and then put it on. This is called a "poor man's type-r." That's my plan for my civic. I've driven an ek hatch with a gsr-poor mans type r, and it was super bad-***. Much faster than the regular Integra gsr.</TD></TR></TABLE>
Smart man! I had a "poor man's type-r" in my gsr and I ran a 14.1 all day with no weight reduction and normal street tires The b16 tranny would also be suggested...
Put a LS motor, no VTEC but more torque than a GSR but less than a type R. If your on the budget, an LS swap is great. Torque motors
Re: b18 on a 97 EK (BaD_NeWz)
B18B
This is the motor in the non Type-R and non GSR Integra.
Pros
Good torque for a 1.8L (127 ft/lbs)
Inexpensive (even cheaper than a B16)
142 hp (more than any stock D series)
Boost heads love them
Cons
No VTEC
Longest B series transmission
B18C1 (or JDM B18C)
These come out of an Integra GSR.
Pros
Good Hp and TQ numbers (170, 121 ft/lbs respectively)
DOHC VTEC
Tons of potential
High revving
Cons
Expensive
Becoming moreso as people keep scooping them up
Slighty longer tranny than the ITR and B16
B18C5 (or JDM B18C)
This is found in the Integra Type-R. IMHO this is the best swap for a Civic.
Pros
GREAT HP and TQ numbers (195 and 134 ft/lbs)
High revving
Hand built motor from Honda
Optional factory LSD
Best transmission for a B series from the factory
Red valve cover
Cons
EXPENSIVE
If JDM ITR is used, the 36mm axle 32mm hub problems occur
Pros
Cons
No VTEC
B18C1 (or JDM B18C)
Pros
DOHC VTEC
Tons of potential
High revving
Cons
Expensive
B18C5 (or JDM B18C)
Pros
High revving
Red valve cover
Cons
EXPENSIVE
Re: b18 on a 97 EK (Earthworm Jim)
we must be bored answering the same "what motor can i, should i put in my civic"
if you want to know look it up, here i'll help you
https://honda-tech.com/zerothread?id=878010
numero sete
09-09-2005 09:24 PM
dirtyapes
27
03-27-2004 05:37 PM
