Please Help. 98 Ls trans problem
Re: Please Help. 98 Ls trans problem (AlexanderTheGreat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlexanderTheGreat »</TD></TR><TR><TD CLASS="quote">I own a 93 civic cx hatch with a 98 integra Ls swap.
Swap was done at baltimore honda boyz back in february. Car drove fine for two weeks. One day i started the car and tryed to put the car in gear and it wouldn't go. Matter fact it wouldn't go into any gear. </TD></TR></TABLE>
Thats why i work on my own stuff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlexanderTheGreat »</TD></TR><TR><TD CLASS="quote">How's that? My trans didn't grind at all. there where no pop outs or grinds what so ever.</TD></TR></TABLE>
my old dx trans did the same thing....imput shaft took a dump on me..
If the slave cylinder is properly actuating the clutch release fork, the only option you have is to pull the tranny and go through the clutch.
Re: Please Help. 98 Ls trans problem (k_motor)
so its not the clutch master cylinder or slave cylinder or clutch plate?
How much will it cost to repair?
or take it back to the honda boyz and have them replace it..or just give you a new trans and u do it yourself!
I would do it my self but ah..... The most i've done is put on exhaust and coilovers. I would need a detailed write up (with pictures) and tools.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlexanderTheGreat »</TD></TR><TR><TD CLASS="quote">so its not the clutch master cylinder or slave cylinder or clutch plate? </TD></TR></TABLE>
You need to check those items. If it goes into gear with the car off, the hydraulic system has failed, or the clutch has a mechanical failure. The transmission should be good.
Re: Please Help. 98 Ls trans problem (Jim Truett)
How do i check for a good clutch master cylinder and slave cylinder?
When my transmission worked fine-- why would i hear a spinning sqeaking noise in neutral?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlexanderTheGreat »</TD></TR><TR><TD CLASS="quote">How do i check for a good clutch master cylinder and slave cylinder?
When my transmission worked fine-- why would i hear a spinning sqeaking noise in neutral? </TD></TR></TABLE>
#1 You can find the Helms manual for your car in .pdf fromat on the internet. This is the first thing you need before you go troubleshooting.
#2 If you didn't purchase a new clutch, or bought a cheap one, it was probably junk from day one. The squeaking is usually caused by the release (throwout) bearing.
