What AC Bracket/Mount for EK with Si swap?
Im wonder what AC Bracket/Mount I have to use for my 96 Civic Hatchback with a 99-00 Si B16A2 swap.
Do I have to use a Si bracket? And what about the compressor, which one do I have to use. I took my car to my uncles shop along with my bracket, and he said it would not fit with my motor.
oh yeah, stock motor is a D16Y7
I did the exact swap. Use your d series compressor, and get a 97 crv bracket. It will bolt up to the b16 block and the d series compressor will bolt up with all 4 bolts no problem. Plus the crv bracket is cheaper than a del sol.
Re: (93Civac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93Civac »</TD></TR><TR><TD CLASS="quote">I did the exact swap. Use your d series compressor, and get a 97 crv bracket. It will bolt up to the b16 block and the d series compressor will bolt up with all 4 bolts no problem. Plus the crv bracket is cheaper than a del sol.</TD></TR></TABLE>
anyone confirm if i can useSi bracket with d series compressor?
Re: (SyDuck)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SyDuck »</TD></TR><TR><TD CLASS="quote">anyone confirm if i can useSi bracket with d series compressor?</TD></TR></TABLE>
u use the crx bracket or a del sol vtec bracket...otherwise u gotta change the compressor for an si compressor and use the si bracket
Re: (123lbc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 123lbc »</TD></TR><TR><TD CLASS="quote">
u use the crx bracket or a del sol vtec bracket...otherwise u gotta change the compressor for an si compressor and use the si bracket</TD></TR></TABLE>
WHAT? WRONG! crx's didn't come with a b series engine. and the compressoer found on a 2000 si, is the same for all civic up to the year using a r134 system.
he can use the del sol bracket, part # 38930-P54-000
or he can use the crv bracket, part # 38930-P7J-000
people suggest the crv bracket because it's cheaper than the sol's.
Re: (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">WHAT? WRONG! crx's didn't come with a b series engine. and the compressoer found on a 2000 si, is the same for all civic up to the year using a r134 system.
people suggest the crv bracket because it's cheaper than the sol's.</TD></TR></TABLE>
Yes. Use the crv bracket. I'm using one at the moment.
Re: (duggy)
thank you guys. the only thing that confused me was that everybody said CRV or Del Sol, not Si bracket.
So, is it confirmed that i CAN use the 99-00 bracket?
also, does the Del Sol bracket have to be from a B16 Del Sol, or will a D-Series Del Sol work too.
Modified by SyDuck at 2:11 PM 7/16/2006
Re: (SyDuck)
Wow...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SyDuck »</TD></TR><TR><TD CLASS="quote">thank you guys. the only thing that confused me was that everybody said CRV or Del Sol, not Si bracket.
Modified by SyDuck at 2:11 PM 7/16/2006</TD></TR></TABLE>
It is NOT confirmed that you can use the 99-00 SI bracket. USE THE DEL SOL VTEC OR CRV!!
Re: (duggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duggy »</TD></TR><TR><TD CLASS="quote">Wow...
It is NOT confirmed that you can use the 99-00 SI bracket. USE THE DEL SOL VTEC OR CRV!!</TD></TR></TABLE>
yes, he can use the 00 si bracket
Re: (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">yes, he can use the 00 si bracket </TD></TR></TABLE>
Nope. I tried this already. Did my swap a couple days ago and tried to use the SI bracket. Only two of the bolts line up. Not all 4.
Re: (duggy)
it was a type-o, i meant cr-v
Re: (skankz_em1)
Bumping an old thread.
So has anyone confirmed that the CRV bracket works on a USDM B16A2 motor w/ power steering yet? I can't seem to find the answer searching.
jadugartir
05-25-2006 08:53 PM
