Vtec Solenoid?!?!?!?
Aight, I just swapped my eg civic with a jdm b16a OBD1. it runs good but when I get to vtec rpms the check engine light comes on and it throws a code 3(map sensor), code 21(vtec solenoid) and a code 22(vtec oil pressure). Then I turn it off and start it back up and the check engine light goes off. I put a GSR vtec solenoid on it to see if it was a defective solenoid, and it does the same thing. But if I unplug either the solenoid or the oil pressure and start it then the check engine light comes on without reving it, so I figure it's got a connection... I don't know what to do. I also cleaned the screan with brake cleaner to make sure it wasn't that.
Re: Vtec Solenoid?!?!?!? (IVGattaBeDreaming)
you check the easiest thing? The oil level? Vtec won't kick in with low oil and low oil pressure, maybe you have a bad oil pump too check those out
10-23-2002 08:20 AM
