6200 rev limit?
Old 07-16-2006, 08:11 AM
tatmark1's Avatar
Default 6200 rev limit?
94 ex w/ jdm b16 from hmo jdm p30
i am hitting some kind of rev limit around 6200 rpm.
i have no codes, no codes stored in ecu.
car runs great and is still pulling right to 6200 the rev limit.
any ideas?
Old 07-16-2006, 08:53 AM
tatmark1's Avatar
bump
Old 07-16-2006, 12:58 PM
tatmark1's Avatar
any ideas to my problem
Old 07-16-2006, 01:22 PM
yecora's Avatar
Default Re: (tatmark1)
try to use another ECU (take for a time from friend or someone, who has b16 with normal rev limit)
Old 07-16-2006, 01:48 PM
midwestsol's Avatar
Default Re: (yecora)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yecora &raquo;</TD></TR><TR><TD CLASS="quote">try to use another ECU (take for a time from friend or someone, who has b16 with normal rev limit)</TD></TR></TABLE> this man tells the truth
Old 07-16-2006, 04:00 PM
tatmark1's Avatar
any one wanna offer a loaner? i dont know a soul who has a b16
Old 07-16-2006, 08:14 PM
tatmark1's Avatar
Old 07-16-2006, 08:41 PM
Sleepy_Red_hatch's Avatar
i may be wrong but the auto ECUs for the B16's revlimit at 6200?
Old 07-16-2006, 08:43 PM
boostin92hatch's Avatar
swap out the dizzy
Old 07-16-2006, 08:52 PM
tatmark1's Avatar
Default Re: (Sleepy_Red_hatch)
i got the ecu with my swap if its auto im pissed, but wouldnt i get a code? it runs great. that was the first time since i swapped it that i reved it that high.
im not going to just throw parts at it
Old 07-16-2006, 08:53 PM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch &raquo;</TD></TR><TR><TD CLASS="quote">i may be wrong but the auto ECUs for the B16's revlimit at 6200?</TD></TR></TABLE>
Nope, redline is like 7800, so rev limit would be after that.
Old 07-17-2006, 07:15 AM
singleslammer's Avatar
Sounds like the timing is off, throw a light on it.
Old 07-17-2006, 12:14 PM
tatmark1's Avatar
Default Re: (singleslammer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by singleslammer &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like the timing is off, throw a light on it.</TD></TR></TABLE>
no timing is set at 16 degrees btc
Old 07-17-2006, 12:36 PM
Ek Forever y0!
Libertariat's Avatar
I would just buy the Ecu from someone. Look on eGay or somewhere.
Old 07-17-2006, 12:57 PM
ThatsMyEG's Avatar
Default Re: (boostin92hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostin92hatch &raquo;</TD></TR><TR><TD CLASS="quote">swap out the dizzy</TD></TR></TABLE>
i hope you dont listen to this guy.. you could check the coil but if your check engine light isnt on i doubt its your distrubutor.. sounds like a ecu or wiring problem.
Old 07-17-2006, 07:18 PM
tatmark1's Avatar
Default Re: (ThatsMyEG)
[QUOTE=ThatsMyEG]
i hope you dont listen to this guy.. you could check the coil but if your check engine light isnt on i doubt its your distrubutor.. sounds like a ecu or wiring problem.[/QUOTE
i know its not the wiring, only wiring that i did was knock. im guessing ecu also, i would like to try someones out. if its ecu i will save up and go p28 and s300
Old 07-17-2006, 08:19 PM
memoryFAB.com representative
spock_rocker's Avatar
im not kidding, check your battery terminals.. i had the same issue!! fixed by putting a shim in the terminal
Old 07-17-2006, 08:43 PM
lshatch916's Avatar
Default Re: (spock_rocker)
when was there an auto b16? sound like u have an auto Ls ecu maybe
Old 07-17-2006, 08:55 PM
Little Hercules
b00sted_hatch's Avatar
Default Re: (lshatch916)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lshatch916 &raquo;</TD></TR><TR><TD CLASS="quote">when was there an auto b16? sound like u have an auto Ls ecu maybe </TD></TR></TABLE>
even the LS rev limit is 7000. your best bet would be the ECU.
Old 07-17-2006, 09:11 PM
lshatch916's Avatar
Default Re: (b00sted_hatch)
on a stock LS auto the rev is 6500. The motor stops making pwr after that. U might be right tho.
Old 07-17-2006, 09:22 PM
H9Omega's Avatar
a friend of mines did the same swap and had the same problem but at the time he had a stock p28 unchipped it wasnt allowing it to rev past 6200 but now he has the proper ecu and takes it to 8200 with his p30
Old 07-18-2006, 06:22 AM
tatmark1's Avatar
it has a jdm p30
bump for some one nearby with an ecu i could try
Old 07-19-2006, 01:36 PM
tatmark1's Avatar
well i reset the ecu and ran it and no problem.
demastus18
07-28-2014 02:27 PM
zayne
Engine Management and Tuning
16
01-31-2014 01:42 PM
hatchet_honda
02-20-2011 11:41 PM
integraboy93
04-29-2007 06:31 AM
kagegod
08-02-2004 06:39 PM
Quick Reply: 6200 rev limit?
