1997 civic lx ac question help (in tx 102 degrees)
here is the run down compressor went out a few months ago
well last week i replaced the compressor and dryer it is only cooling around 80 degrees and compressor kicks on and off every couple seconds
i was told putting too much oil in the compressor and dryer can not make it cool enough
what are other ideas
Re: 1997 civic lx ac question help (slow99gsr)
can you tell us the exact procedure you took in replacing/recharging your a/c system? then we might be able to figure out if you don't something wrong, or not
Re: 1997 civic lx ac question help (SRd240sx)
1did vaccum on ac system on car before pulling off compressor
2swapped compressor
3 swapped dryer ( between both used a small can of the ac oil)
4vaccumed the ac system again
5 charged
6 blowing cool not cold
2swapped compressor
5 charged
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow99gsr »</TD></TR><TR><TD CLASS="quote">1did vaccum on ac system on car before pulling off compressor
2swapped compressor
5 charged
6 blowing cool not cold</TD></TR></TABLE>
You don't need to vacuum prior to removing the compressor.. but too late now, so use it for future reference.
Was it pulling -29inches of mercury vacuum?
Modified by SRd240sx at 11:57 AM 7/22/2006
2swapped compressor
5 charged
jlamaster
10-01-2004 07:12 PM
