Gauge cluster problem
would a burn mark (thats what it looks like) on the back where the circuits are on the cluster be the culprit on why my cluster lights dont work? fuses, wiring, bulbs everything is fine. i had a jdm cluster before working fine and changed it to the EX one
Re: Gauge cluster problem (Digithalgravel)
yes, that could possibly cause that. Try claening it off and try it again. Otherwise, it could be your dimmer switch.
which fuses did you check, and best way to tell, if you got a extra cluster laying around throw it in, if it lights up, then its that other cluster. Or a bulb on the ex cluster could just be out?
Re: Gauge cluster problem (Gutted Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_fan »</TD></TR><TR><TD CLASS="quote">yes, that could possibly cause that. Try claening it off and try it again. Otherwise, it could be your dimmer switch.</TD></TR></TABLE>
well its burned and it split so its not a straight through circuit. i was thinking of soldering together would taht work? lol. its not the dimmer switch cuz before i was using a diff cluster and it worked fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gutted Si »</TD></TR><TR><TD CLASS="quote">which fuses did you check, and best way to tell, if you got a extra cluster laying around throw it in, if it lights up, then its that other cluster. Or a bulb on the ex cluster could just be out?</TD></TR></TABLE>
vtec.dc2
05-22-2006 12:36 PM
