rings are fried
rings are fried
wuts up guys. hey i got a quick question. i just bought a 92 civic hatchback and i think the rings are fried. it smokes in high rpms and burns a lot of oil. can that be fixed somehow or should i swap it out with something else? thanks
Re: rings are fried (P_dizzle24)
pull your head
pull the pistons
re-hone cylinder walls
new rings and properlly gapped
re-instaul
if you have never done this type of work, it will probablly be alot easier to jsut swap or drive like a normal person and shift in the lower rpms.
g'luck
pull the pistons
re-instaul
g'luck
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_dizzle24 »</TD></TR><TR><TD CLASS="quote">wuts up guys. hey i got a quick question. i just bought a 92 civic hatchback and i think the rings are fried. it smokes in high rpms and burns a lot of oil. can that be fixed somehow or should i swap it out with something else? thanks</TD></TR></TABLE>
It's cheaper to swap in a good running engine. Fixing the current one would involve disassembling the entire engine, boring out the cylinders, and installing new oversized pistons and rings. The parts, machine work, and especially the labor will add up to more than a used engine.
