which linkage or shifter do I use for a b18 swap?
at the jetties fishin'
I've got the main list down of stuff I need but I cant seem to find anywhere that mentions whether or not I have to also grab the shifter/linkage from the integra when I pull the swap out?
my car is an auto 93 dx hatch
and the swap donor is a 91 LS 5speed
I've got got a 94 lx sedan 5speed if I need to grab anything from it.
I prefer to just swap straight to the manual LS setup from my auto dseries and just use the cable clutch setup.
I think I need to use the LS linkage with the civic shifter but cant confirm this anywhere....anyone know for certain??
cute little bastard
Re: which linkage or shifter do I use for a b18 swap? (stackz)
94-up Integra Linkage for civics.
https://honda-tech.com/zerothread?id=983454
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi »</TD></TR><TR><TD CLASS="quote">you can use the stock d series shifter</TD></TR></TABLE>
no it won't. they don't bolt onto the tranny the same
edit: yes the shifter, not the linkage though
Modified by SkoundrelUSA at 12:53 PM 7/15/2006
Re: which linkage or shifter do I use for a b18 swap? (SkoundrelUSA)
you can use a b16/b18b/b18c/b18b5 linkage but i dont know about the Delsol b16a3 linkage but w/ any civic shifter (but you need washers in between the shifter and the linkage so it wont be soo sloopy) or any b-series shifter..
alright I just finished pulling out the swap from the donor car but I still dont see why I cant use the shift linkage from the DA it looks to be about the right length?? I'm taking it anyway just in case.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi »</TD></TR><TR><TD CLASS="quote">you can use the stock d series shifter</TD></TR></TABLE>'
stop providing wrong info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stackz »</TD></TR><TR><TD CLASS="quote">alright I just finished pulling out the swap from the donor car but I still dont see why I cant use the shift linkage from the DA it looks to be about the right length?? I'm taking it anyway just in case.</TD></TR></TABLE>
it wont work, it will be a 2-3 inches shorter OR longer...cant remember. then it should be so the shifter will sit funny. I helped a friend do a b18a swap into his 4-dr and he tried the same thing.
he had his dad cut the shift linkage and extend/shorten it more
Re: which linkage or shifter do I use for a b18 swap? (Mr.RHTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner »</TD></TR><TR><TD CLASS="quote">'
it's not wrong info, you can use the actual shifter it's self.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::ferio::.. »</TD></TR><TR><TD CLASS="quote">you can use a b16/b18b/b18c/b18b5 linkage but i dont know about the Delsol b16a3 linkage but w/ any civic shifter (but you need washers in between the shifter and the linkage so it wont be soo sloopy) or any b-series shifter..</TD></TR></TABLE>
as for the del sol linkage, that cannot be used.
