AC questions.. searched
Hello i have a 94 coupe with a gsr in it... the guy said he had ac in it.. but took it out because he was going to turbo... now my question is.. im going to put the ac back in... but what do i need.. i have the dcondenser for the car.. 3 out of 4 lines... do i need a b series compressor? d series? does it matter? anything else? i dont know..
Re: AC questions.. searched (vlc92189)
finish getting all the lines, the dryer, and your going to need a compressor bracket from either delsol, or a crv so you can continue to use the d-seires compressor.
del sol part number:38930-P54-000
crv part number 38930-P7J-000
believe it or not, the crv bracket is a couple of bucks cheaper.
alright.. thanks.. if i hjappend to find maybe an integra.. could any b series compressor work? and what is the dryer? imma go to junkyard.. so how much you think all new lines.. compressor.. and dryer would be?
Re: (vlc92189)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vlc92189 »</TD></TR><TR><TD CLASS="quote">alright.. thanks.. if i hjappend to find maybe an integra.. could any b series compressor work? and what is the dryer? imma go to junkyard.. so how much you think all new lines.. compressor.. and dryer would be?</TD></TR></TABLE>
the dryer is alittle canister that sits behind your driver headlight that has lines running to it. not sure how much will this stuff cost at a junk yard, being that i purchased a whole kit, and if the yards near you are anything like the ones near me, then good luck.
as for the b-series compressor. no they won't fit. your d-series lines won't match up to those on the compressor(i mean the threading on the lines.). it's just easier to use the smaller compressor. as for the brackets, you have a better chance finding them at the dealership than the junk yards.
the 2 parts numbers i gave you, the smaller compressors will bolt right on.
those cars that came with those brackets used the same compressors as the d-series engines.
Re: (philosofy1)
i have a b-series compressor for $50 + shipping if you're interested. out of a 99 civic si. works with 94+ integra b18b and b18c1 and b16a also. as long as you have hte a/c bracket on your b18c then you're good, if not, tehn look into getting a del sol bracket + d series compressor if that's cheaper. either route will work fine
