Required Engine Harness for 1999 Civic Si motor in 92-95 Civic
Tried searching, but couldn't find a pin point for the answer to my question.
Im purchasing a 99 Civic Si motor with no engine harness.
On a previous civic I owned, I used a 98 R motor with 98 R engine harness.
I wanted to question, what engine harness should I be in the market to purchase for this 99 Civic Si B16A2 Motor?
Any help would be appreciated
Thanks
Thanks
Re: Required Engine Harness for 1999 Civic Si motor in 92-95 Civic (NWP4LIFE.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NWP4LIFE.com »</TD></TR><TR><TD CLASS="quote">Tried searching, but couldn't find a pin point for the answer to my question.
Thanks </TD></TR></TABLE>
90% sure you want the 99-00 si harness, but i think a obd1 ex-si harness will work with adding a few sensors, and chaging the dizzy with a obd1 and the injectors aswell, or even use ANY 92-95 civic harness and add the vtec oil pressure switch + solenoid to the list of plugs to add
HT Order of Merit
Re: Required Engine Harness for 1999 Civic Si motor in 92-95 Civic (Sleepy_Red_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch »</TD></TR><TR><TD CLASS="quote">
90% sure you want the 99-00 si harness, but i think a obd1 ex-si harness will work with adding a few sensors, and chaging the dizzy with a obd1 and the injectors aswell, or even use ANY 92-95 civic harness and add the vtec oil pressure switch + solenoid to the list of plugs to add</TD></TR></TABLE>
You want to stay OBD1 obviously, so use the harness you have in your car now. You will have to extend the O2 sensor wiring, and a few things. You will also have to add a knock sensor, and the VTEC wires if you haven't already. Use an OBD1 distributor, injectors and OBD1 P30 ECU, and you will be perfect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch »</TD></TR><TR><TD CLASS="quote">90% sure you want the 99-00 si harness</TD></TR></TABLE>
90% sure and 100% wrong, which confuses me even more because the rest of your info is pretty spot on.
92-95 = 2-piece engine harness
96-00 = 1-piece engine harness
Re: Required Engine Harness for 1999 Civic Si motor in 92-95 Civic (EE_Chris)
Thanks alot guys, I really appreciate all of your input.
My main concern is will an OBD2A engine harness be plug n play on this 99 Si B16A2 motor?
Thanks again
Thanks again
Use an engine harness from an obd2 gsr/type R. You will haveto jump the neg. wire from the dist to the driver side shock tower for your rpm tach to work. You don't have to worry about obd2 sensors like the crank angle position that is on the oil pump since the obd1 ecu does not look for it.
When you use the obd 2 harness makes it plug & play with the alt/dist/fuel injector clips.
Good luck
Good luck
boostincoupe
09-10-2006 08:34 AM
MattTwinTurbo
11-18-2002 01:35 PM
