integra and civic knuckles are they the same?
are the knuckles the same, i am replacing some wheel bearings for a customer and he does not want down time, i have an extra set from my cx hatch that i was going to just put new bearings in and then chage them with his,
Modified by beaneg6 at 11:32 PM 10/19/2006
Re: integra and civic knuckles are they the same? (beaneg6)
Civic EX and Integra knuckles are the same. The ones that use the 262mm front rotor.
Check the part numbers for the wheels bearings at http://www.slhondaparts.com
Re: integra and civic knuckles are they the same? (BlueIntegraBoy)
Your CX knuckles are not the same. The integra brakes won't work on em. The only civic knuckles that ARE the same ar ethe ex/si.
Re: integra and civic knuckles are they the same? (Eyal 951)
even if i use his brakes and calipers, they wont fit on my knuckles?
if i use cx knuckles with ex/si/integra calipers and rotors, will it work?
I'm almost 100% sure they wont. When doing the brakes swap, you ned the knuckles. I did the GSR swap, and raplced everything.
Im sure the caliper mount is in the wrong place and such.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaneg6 »</TD></TR><TR><TD CLASS="quote">if i use cx knuckles with ex/si/integra calipers and rotors, will it work?</TD></TR></TABLE>
they look the same, and technically you can put the cx on a integra (why i don't know). but the integra knuckle has a larger diameter for the wheel bearing, the cx and dx model civic use a smaller one in diameter. tell you customer to learn to wait, and that he needs patience.
boost and bass
05-25-2009 07:14 AM
jpb105079
08-19-2004 11:08 AM
