d16z6 b0ttom block and d16y8 head will it work ?
^^^^^^^ will it be more than stock single cam v-tec ? or the same ?
is it just a simple plug it up and play ?
Re: d16z6 b0ttom block and d16y8 head will it work ? (deadline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadline »</TD></TR><TR><TD CLASS="quote">^^^^^^^ will it be more than stock single cam v-tec ? or the same ?
is it just a simple plug it up and play ?</TD></TR></TABLE>
uhh lets see!
you need either:
7 Z6 head bolts and the Y8 head bolt in the vtec solenoid area
or
7 Y8 headbolts and a Z6 headbolt where the vtec solenoid area is
i cant remember which is which, search, you'll find it
uhh lets see!
you need either:
or
Re: d16z6 b0ttom block and d16y8 head will it work ? (Sleepy_Red_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch »</TD></TR><TR><TD CLASS="quote">
uhh lets see!
you need either:
or
i cant remember which is which, search, you'll find it</TD></TR></TABLE>
any threads bout dis stufff ?
uhh lets see!
you need either:
or
why not just stick with a z6 head? they both put out similar numbers and (to answer your question) are both sohc vtec.
Re: d16z6 b0ttom block and d16y8 head will it work ? (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">Have fun hacking and halfassing your D16Z6 distributor onto the Y8 head . . .</TD></TR></TABLE>
do it the easy way and get a D15b7 Distributor... OBD1 = no wiring issues and bolts directly to the y8 head
Re: d16z6 b0ttom block and d16y8 head will it work ? (teal_dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teal_dx »</TD></TR><TR><TD CLASS="quote">
do it the easy way and get a D15b7 Distributor... OBD1 = no wiring issues and bolts directly to the y8 head </TD></TR></TABLE>
koo....these tips are well needed....
Unceasing Measure
I've done it before. It's more of a PITA than it's worth, and I've done this many times Getting ARP studs for the wrong setup sucks....twice
neroren
03-16-2009 04:26 PM
Jakester9500
01-15-2007 08:23 PM
95-CivHB-VX
13
08-21-2004 11:07 PM
