what is in the 93 civic
what does the 93 civic ex come with engine wise. i have an accord and i am buying this civic for like 500 and i am wondering what the engine size is so i know what i am working with or if i am swapping it. i believe they are 1.5l sohc but unsure on if they are vtec or not
be professional
Re: what is in the 93 civic (HaNsElBaDaSs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HaNsElBaDaSs »</TD></TR><TR><TD CLASS="quote">what does the 93 civic ex come with engine wise.</TD></TR></TABLE>
D16Z6
- 1.6L L4 16V SOHC VTEC
- 125 hp @ 6600 RPM
- 106 lb-ft @ 5200 RPM
- 9.2:1 static compression
- 4800 RPM VTEC, 7200 RPM redline, 7500 RPM rev limit
- P28 OBD-1 PGM-FI (MPFI)
Found in:
- '92-95 Civic Si 3dr EH3
- '92-95 Civic EX 4dr EH9
- '93-95 Civic EX 2dr EJ1
- '93-95 del Sol Si 2dr EH6
Manual transmission ratios (EX):
1 - 3.250:1
2 - 1.900:1
3 - 1.250:1
4 - 0.909:1
5 - 0.702:1
FD - 4.250:1
D16Z6
- 125 hp @ 6600 RPM
Found in:
1 - 3.250:1
2 - 1.900:1
3 - 1.250:1
4 - 0.909:1
5 - 0.702:1
FD - 4.250:1
be professional
Re: (HaNsElBaDaSs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HaNsElBaDaSs »</TD></TR><TR><TD CLASS="quote">thanks for the info i appreciate it. i think i am going to jsut swap the engine for a b18c5 and just build it a lot.</TD></TR></TABLE>
If you're going to be replacing internals, don't start with a B18C5. There's no point in paying extra for internals that you won't be using.
Re: (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
If you're going to be replacing internals, don't start with a B18C5. There's no point in paying extra for internals that you won't be using.</TD></TR></TABLE>
If you have your heart set on cams and internals, go with the H-series. They are great motors to build and have good base power and torque.
h series is the accord type engine that is going in my accord i think i will go with the gsr then and put a type r head on it and maybe type r pistons and then skunk2 intake manif elback throttle body dc sports header and aem fuel rail and high flow fuel pump and injectors. i think that should be good enough for me... for now
be professional
Re: (HaNsElBaDaSs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HaNsElBaDaSs »</TD></TR><TR><TD CLASS="quote">i think i will go with the gsr then and put a type r head on it and maybe type r pistons and then skunk2 intake manif elback throttle body dc sports header and aem fuel rail and high flow fuel pump and injectors.</TD></TR></TABLE>
If you're going to do that, then just start with the Type-R engine.
I had suggested that you shouldn't start with the ITR engine because you mentioned "building it a lot," so I assumed you would be tearing it down and replacing pistons, rods, cams, valve springs, etc.
Re: (HaNsElBaDaSs)
If your going to get that EJ coupe...and it has the D16Z in it already...you can boost it for an okay price and still get a thrill...but like the saying...theres no replacement for displacement...start with a B18C1...and do your 'super' buildup. Instead of buying the B18C5 and replacing all those precious internals.
Re: (HaNsElBaDaSs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HaNsElBaDaSs »</TD></TR><TR><TD CLASS="quote">new engine = 600 dollars
new parts and accessories = 300 dollars
passing an undercover cop and him not able to catch you... Priceless
Boost is the real mans best friend dogs are number 2</TD></TR></TABLE>
I'm quite curious as to your signature.
What engine can you get for 600, upgrade for 300, and blow away a cop car?
Re: (HaNsElBaDaSs)
ls vtech, the poormans type r, you can always boost the ls as well, thats one hell of a jump for your first swap. no offence but you might end up with something a bit over your head. if you have it in your head " oh i gotta type r" your gonna drive the crap out of it and things will go out left and right, a buddy of mine adam has a 95 ex coupe with an itr "b18c5" the car is nutz put constantly has issues.
if this would be your first swap ide either do an ls swap than boost it and put the gsr head in later for the ls vtech once you have become more familiar with your car and the added horsepower. all else fails start off with a b16
Re: (deadline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadline »</TD></TR><TR><TD CLASS="quote">only got potential if u r goin turbo.......other than that it sucks harder than it blows</TD></TR></TABLE>
or put some b16 pistons in it, plus some bolton's and put down more whp than a b16
be professional
Re: (dzminiz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dzminiz »</TD></TR><TR><TD CLASS="quote">
or put some b16 pistons in it, plus some bolton's and put down more whp than a b16</TD></TR></TABLE>
You have no idea what you're talking about.
Have fun putting 81mm pistons in a 75mm bore.
How do you plan to extend the D16's torque curve an extra 1000 RPM (in order to equal the peak horsepower of a B16A) with just bolt-ons?
Re: (vtec4lyfe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec4lyfe »</TD></TR><TR><TD CLASS="quote">well most of them have an engine, seats, stearing wheel, cassete player, tires, axles
you know most of the usual stuff</TD></TR></TABLE>
Nice try on being cute, but he did specify and say engine wise. Could you possibly contribute in that field?
Re: (NINJA-EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NINJA-EG »</TD></TR><TR><TD CLASS="quote">If your going to get that EJ coupe...and it has the D16Z in it already...you can boost it for an okay price and still get a thrill...but like the saying...theres no replacement for displacement...start with a B18C1...and do your 'super' buildup. Instead of buying the B18C5 and replacing all those precious internals. </TD></TR></TABLE>
let him buy the type r, then when he goes to build it , he can sell me all the type r parts but no forreal, i love my gsr..
