tire size
tire size
i currently have 14 inch wheels on my 92 civic 4dr and am planning to get 17 inch rims with low profile tires, how much higher estimated is my car going to rise of the ground???
Re: tire size (ic89)
It shouldn't raise any or + or - very little if done properly.
Do some research HERE
There are many other sites to help you as well. Google it if this don't help you. :D
I went from my stock 14" steelies to some 17s with 215/40/17 tires and the difference, while noticable, isn't huge.
Honestly though, I wish I had just gotten 16s, the 17s are just massive. Though I still love them, I'll probably get a seccond set of 15s for racing with.
HT White Ops
Re: tire size (Felliph3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Felliph3 »</TD></TR><TR><TD CLASS="quote">around 2 inches</TD></TR></TABLE>
How can you say that without knowing his tire sizes?
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ic89 »</TD></TR><TR><TD CLASS="quote">i currently have 14 inch wheels on my 92 civic 4dr and am planning to get 17 inch rims with low profile tires, how much higher estimated is my car going to rise of the ground???</TD></TR></TABLE>
Assuming that you currently have 185/60-14 tires (do you?), and that you'd be switching to 205/40-17 tires, your ride height will be raised approximately 1/2", taking into account differences in tire radius and sidewall flex. Regardless of that, it's still going to look like a roller skate, particularly if you have stock springs.
HT White Ops
Re: tire size (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">Assuming that you currently have 185/60-14 tires (do you?), and that you'd be switching to 205/40-17 tires, your ride height will be raised approximately 1/2", taking into account differences in tire radius and sidewall flex. Regardless of that, it's still going to look like a roller skate, particularly if you have stock springs.</TD></TR></TABLE>
Correct
Moron
Correct
Moron
using simple math, with stock 185/60/14 tires your overall diameter will be 22.74 inches
with 205/40/17 tires your overall diameter will be
23.46 inches
formula used
[(tire width X aspect ratio) X 2] / 25.4
23.46 inches
formula used
