Tach........????
Old 10-19-2006, 07:03 AM
irideslammed5021's Avatar
Default Tach........????
I have a stock cluster with no tachometer, so i went and bought an autometer tachometer, does anybody know how to hook it up, i tried it myself and i failed, i tried wiring diagrams and all if anyone knows i could really use the help
Old 10-19-2006, 07:07 AM
0334973's Avatar
i believe some have 3 and some have 4. give us the number of wires and their color and it will be easier to help you
Old 10-19-2006, 07:32 AM
Default Re: (0334973)
it has 4 wires, white-dimmer switch (got that already), Black-Ground (got that alreardy) Red and a Green, i know one is for power but i am not sure about the other, and i dont know where to hook the two up at
Old 10-19-2006, 07:41 AM
thelucysong's Avatar
Default Re: Tach........???? (irideslammed5021)
Red - Power (Any power source in your fuse pannel that will shut off when the car is turned off. Maybe cigarette lighter?)
Green - Blue wire off of the distributor. (It carries the RPM signal. There also might be another blue wire capped off next to your brake fluid canister, depending on what year and model you have. That will carry the signal also.)
Old 10-19-2006, 07:47 AM
Default Re: Tach........???? (thelucysong)
i didnt see a blue wire off the distributor, or by the master cylinder, i will keep looking cuz i swapped it to ls/vtec, thanks for all the help, if anybody knows anymore it would be appreciated
Old 10-19-2006, 07:51 AM
Look for the wires coming off of the bottom of the dist. There is a dark blue one, thats your wire. Even with a swapped whatever, the dist wires should all still be the same.
Old 10-19-2006, 08:21 AM
thanks for the info... i got it to work
Old 10-19-2006, 09:13 AM
harley06's Avatar
try to see if you have a yellow wire with a green stripe, hook the green up to that. its by the distributor
and you can hook up the red to an empty slot in the underdash fuse box
Old 10-19-2006, 09:17 AM
philosofy1's Avatar
Default Re: Tach........???? (harley06)
of coarse he is installing this inside of the car, why send him to the distributor when the wire is already at the harness behind the cluster. why not send him there where accessing and wiring it would be easier and probably neater.
Old 10-19-2006, 10:44 AM
Syndacate's Avatar
Default Re: Tach........???? (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">of coarse he is installing this inside of the car, why send him to the distributor when the wire is already at the harness behind the cluster. why not send him there where accessing and wiring it would be easier and probably neater.</TD></TR></TABLE>
LoL, Yeah I'm wondering the same thing..
That same wire goes behind your cluster....
Fezzie
13
06-05-2006 10:23 AM
SHIFKU(EF9 HOPE FUL)
09-21-2005 08:02 AM
GSRCRXsi
05-22-2005 08:01 PM
LS stretch
07-30-2003 12:41 PM
Quick Reply: Tach........????
